Got a few questions.
I'm planning on setting up a RAID 0 array with two seagate 7200.10 250gb drives. I'm going to do this on an IP35 mobo that i just got today, it came from the ocuk b grade section and has no driver discs or even the backplate.
Does anyone know if you have to setup the RAID using the drivers from a floppy disc or can it all be done in the bios on this board?
Is installing windows any different, I seem to remember it asks about if your using RAID as soon as it loads from the cd?
Also does partitioning the resultant 500GB drive work the same way as it does with a single hard drive?
Finally would I be able to add non RAIDed drives along side the 2 aforementioned drives?
Sorry for all the noob questions, never tried RAID before!
