Raid partitions
25 Nov 2003
Milton Keynes
Hi , i have 2 x 250 hd's that i want to put into Raid 0 , can i partition them after the raid is set up , i know you couldnt at one time with partition manager.
Want to set them up as the boot disk , load xp and then partition it into 100 - 400 , 100 for the xp installation.
Thanks.
as far as i know, when the drives are raided the whole array acts like 1 single drive, and so it should be no different to partition then a non raided drive.
