Raid questions
23 May 2006
Good morning :)
I have jumped on the Windows 7 bandwagon and got my copy on order, after ordering this I decided I would like to get a new drive or 2 to have a nice new clean install, my current drives are quite poor and old. After speaking to a friend who works for an IT reseller, he told me he would send me a couple of WD 500GB Caviar Black drives, this was a little unexpected, but good times :)
Anyway, with this in mind I have come to the conclusion that perhaps it would be best to raid 1 both drives and install my new OS and games. However, my question is this, would I be best off getting a couple of smaller drives, say WD Caviar Blue, putting them in raid 1 and just having the OS on there, while my 2 WD Blacks handle all my games and data in raid 1. Would that be much better than having all my data just on one raid?
Sorry for making this a little long winded, and in case you could not tell, I have very little knowledge about raid set-ups, any bits of advice would be greatly appreciated. Oh and all I do with the PC really is play games, primarily World of Warcraft.
I advise reading through the RAID pages on wikipedia, good introduction.
Frankly having one raid setup for your OS and another raid setup for your applications is a matter of taste, the same as having one drive for each, essentially.
Personally, I'd put all programs (ie, OS, program files directories, games and apps) on one drive/array, and all data (mp3s, movies, whatever data files you use) on another. Simply so you can make the former quite streamlined and on very fast drives, and the latter on slower, larger capacity drives.
RAID 1 will give you data integrity in case the drive fails, it can speed up read speeds a bit. Good luck!
Personally I would go with using them separately and backing up anything important to the other disk. RAID is not backup and having two disks can speed things up.
