Raid stripe
26 Jan 2006
I am redoing my raptor raid 0,
what you think about stripe size? 32K or 64K? (on board ULi supports up to 64K only :p)
Thanks
Are you working with mainly small or large files? Because it slightly affects the speed/wasted space depending on which you work with most and the stripe size you select. I'd probably opt for a 64K stripe size if you would be working with a mix or mainly larger files. :)
