- 9 Nov 2005
- Southampton, hopefully not too hot, or too cold
I finally put together my new rig yesterday,as per sig. However, I came unstuck when trying to set up my 2x WD 3200AAKS in RAID 0...
I created a RAID volume in the RAID bios, but when Vista64 invited me to load a RAID driver, the one supplied on the motherboard's driver CD was not recognised (I had read that Vista does not depend upon a floppy for the RAID driver and that it can also read CD/DVD and USB... Shame a suitable format besides a floppy installer was not on the disk).
I then rescued a floppy drive from an old system, along with an old 1.44MB floppy disk, both of which seemed so archaic (having not used either for several years). I managed to get the floppy formatted, but when I tried to run the RAID floppy installer, it refused to install (complaining of head/sector errors).
So I ended up installing Vista64 in a non-RAID environment, in a 30000MB partition, while a 60000MB partition was created on the same HDD for games. It runs fine, but I would like to set up a RAID 0...
The motherboard drivers CD has an Intel Matrix file, in the same folder as the floppy driver installer. Could I use this to convert my new Vista installation into RAID 0, or do I need to borrow/buy a new floppy drive and disk to start over at some point (after gettting a gaming fix following a drought of a few weeks?
Thanks in advance for knowledge given by gurus
