Hi All...after some advice or help please...
I have a MSI x570 tomohawk wifi board
ryzen 5950x
32gb ddr4 3600
rtx3060 12gb
two samsung 980 pro m.2 gen4 drives in raid (bios raid setup)
one 120gb ssd on sata port
The issue i am having is slow read/write speeds on the two m.2 drives which are in a raid array. Currently with crystal mark i am only seeing 1800mbs read and write, which is way below the 7000mbs i should be seeing. Both m.2 ports are listed as pcie 4.0 x4, so should they not be running at a much higher speed? I understand that the upper m.2 runs on the cpu and the lower m.2 on the chipset....
can anyone shed any light on this? - tried everything to get it to increase, but no luck.....can anyone recommend the best bios settings so i can check i have not missed anything...or should i just junk the raid0?
many thanks i advance
ryzen 5950x
32gb ddr4 3600
rtx3060 12gb
