RAID1 - Pre-format drives?
25 Oct 2009
Caerphilly
I have 2 WD Caviar Blacks that I need to setup in a RAID 1 array.
Question: Should i format them first with NTFS through Partition Magic, Partition Manager etc before setting up the Raid Array or not?
I've had trouble with Windows 7 seeing the RAID, (or I just hadnt completely set it up properly).
Any thoughts?
Not needed my friend. I'm an ICT Engineer.
I was just curious as to how other people setup their RAID with W7.
I've now formatted the drives and will set up the RAID1 array tonight after work. :)
Any thoughts?
There's no need to format the drives first, you will need to format the array once it's created though.
There shouldn't be any problems getting Win 7 to recognise the array as long as all the right drivers are in place (7 comes with most of the popular ones built in so you may not need to do anything).
