- 30 Oct 2002
- Inverness (UK)
Down to 4
OK, what I have currently:
PERC 5/i running RAID5 with 3 x WD20EARS.
The drives have been fine, no problems considering they are 'green'.
What I'm moving to:
RAID array going to a HP MicroServer.
So - Need a half height card.
After spending many days hunting for reviews / reading forums etc I have come up with 4 cards.
One caveat - The BBU for the 3mware seems to be significantly cheaper than any of the rest.
Required:
SFF 8087 connector
RAID5 write performance to be comparable to PERC 5/i
Low Profile
Wanted:
BBU available and not extortionate
Ideally anyone who has run 'green' drives on these controllers
HDD LED Headers would be nice
So - if you were buying a RAID Card for them and wanted decent performance, would you go with one of these 4?
If so, which one of them?
And if not - Would you suggest a cheaper card?
One thing to note about the Adaptec is that it's dual core oO
Probably overkill but seemed interesting none the less.
Also there are issues with the PERC on an Intel mobo - None of these cards have issues running on non-server hardware?
Thanks for any tips / advise. Seems not a lot of people within google use these for home setups much.
What I'm moving to:
- 3mware 9650SE-4LPML
- LSI 8704EM2
- Areca ARC-1210
- Adaptec ASR-5405
Required:
SFF 8087 connector
Low Profile
Wanted:
