I am planing to buy a large ssd about 120gig but i was wondering if i get better performance if i raid0 two 60gig ssds.
Don't think you'll notice any real world performance increase for general use, although if you regularly work with large (video) files (copying/moving) or often unzipping large archives it could be helpful...
I thought you got double the speeds with Raid SSD's...
you do but you loose features such as TRIM on most drives also boot times are a little longer.
I had 2 30gb vertex OCZ drives in Raid and they were fast enough for sure and for the £130 or so I paid for the both it was worth it but I wanted bigger so went and bought a 120gb vertex 2![]()
Boot times are only longer because you have to wait (1 second on mine) while the splash/bios screen display to allow you to go into the RAID bios. Once that is loaded two drives will demoilish a single drive on the way to loading windows. Of course when you're in windows the performance will again be double. The drawbacks are that unless you use a Sandforce of similar architect controller, you will have to secure erase/re image the OS again when it slows down. So far I have not found this to be teh case with the Revo.
