Not sure about the sensor in the mirror, but I'm pretty sure there is a bit of plastic cover that runs from the attachment point to the top of the windscreen.unclelonghair said:Do you have the auto dimming rear mirror? (Has a little light sensor at the bottom, and no lever to manually change it) AFAIK the two came together as one option. The other way to tell is if there is a piece of plastic running from where the mirror attaches to the windscreen to the top of the windscreen.
Yeah I guess the auto option does suck. Especially when stopped at traffic lights as you can see **** all.NickXX said:You'll see it behind the rear view mirror. Some Mk5 SE's have it as standard. Mine didn't, however whenever you stopped in traffic, the wipers would stop wiping until you started off again so this might be confused with auto-wipers. They're probably speed sensitive too. The auto-wipers will only work when you set the wiper speed to the intermittent setting.
Auto-wipers suck anyway.
