- 23 Sep 2012
- South Yorkshire, UK
When i built my I7 6700k system back in 2015, i used a 32GB 2 dimm kit, this one:
Corsair LPX Vengence 32GB kit (red version)
Now, i'm planning to build a new system, and i want to try and reuse as many parts as i can, I had been hoping to reuse my NH-D15, but might not be able to with the board i'm planning on going with, as the cooler will block the top pcie slot, and I've heard the stock cooler that comes with the 3900X is loud, so i'm going for an H100X (my first AIO)
Now, my question is this: Can i use this ram with my new main board (looking at the Asrock 570M Pro4, as it seems to be the only mATX board i can find on OC that isn't out of stock, at least with the 570 chipset), but the module code number (CMK32GX4M2A266) isn't listed in the HQL list Asrock posted for the 3900x Ryzen chip, would i still be ok using it? I really want to avoid buying new memory, this build has got expensive as it is, i'm just glad i'm not getting a new GPU as well.
