Ram for 5600X build
10 Aug 2015
Just built a new rig
5600X
MSI x570 tomahawk
https://www.overclockers.co.uk/cors...zen-tuned-ddr4-memory-dual-kit-my-4c1-cs.html
When trying to OC the Ram using xmp profiles I can run it at 3600 but 4000 is no good and clear the CMOS
Just wondering if I got the best ram now. Should I have got https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-001-8p.html
As its better die and lower CAS
How much difference does this really make in gaming performance E.G FPS ?
Thanks in advance
I split the difference and went with 2x 16GB 3600 C16. Samsung B-Die seems to be the secret sauce with Dual Rank. I'm on an ITX board so limited to 2 dimms though. 4x8GB 3600 C14 Samsung B-die is probably the top of the mountain if you can find it/afford it.
