RAM Issue?
28 Jan 2011
Hey guys,
I have recieved all my equipment and so far is running well, not long set it up.
The issue I have is that im on Windows 32 bit so I know its only allowed 4gigs, but when checking the BIOS it says under ram amounts of 4gigs, surely it should be 8 in the BIOS?
Can someone please shed some light on this, plus I will upload photos once its all setup, desk too etc..
RTJ
do you have onboard gfx as this will use some ram?
edit : didnt read properly, yes it should show up as 8 in bios. try 1 stick at a time.
OK will try that Stulid, and para.
Due to the CPU cooler I had no space in slot 1and2 so had to use 3-4, would that affect it at all also?
RTJ
Hey guys, had some problems but after some changing the RAM strips around etc it now registers as 8gig in BIOS and in windows, now I just need a 64 bit install of windows 7 :(
RTJ
not all keys work with both versions, only the retail ones. if he had a retail key he would have been supplied with both discs so chances are its the oem key.
Ah, ok. I get mine through a MAPS subscription and can install either 32 or 64 with the same key. (Also why I have Pro and Ultimate and not the "Home" varieties)
Cheers :)
