Hi,
I built my first PC a few weeks and decided to check the ram settings were correct only recently.When I have tried using the XMP Profile, the system became unstable (BSOD, Freezing and random reboots). On default it was fine and when i entered the settings manually it works but it is a little unstable, some BSOD. I have tried to seach why but haven't been able to. Not sure if there is a fault with a component. Everything is on stock settings.
I ran Memtest with XMP enabled and it had errors on all sticks and slots. With it on default it had no errors.
Spec are:
Gigabyte Z97P-D3
4690K
8GB Teamgroup Vulcan 2133Mhz
R9 270
550W Superflower PSU
SSD & HDD
Spec are:
Gigabyte Z97P-D3
4690K
R9 270
SSD & HDD
