Ram water blocks.
It looks like it should work. A quick google shows the heatsinks in use with a different block but as long as they are the same length with the attaching screws in the same place I can't see why it wouldn't work. Have you seen the Aquacomputer and XSPC complete kits?
Personally I really don't see the point but it's up to you.
i have EK cpu and gpu blocks and wanting to keep with EK.
i also think there is no point but it will then be a fully water cooled system, and they look nice
Edit: looking at the Aquacomputer one, i could be interested in the it dose look nice. i may have a google.
