hi everyone.
I am having major issues at the moment and i am at my wits end. I come askign for your knowledgeable assistance to get my machine working finally.
basically i have a rampage formula and i cant get the thing to boot reliably. i bought the new board after mistakenly thinking my p5bwas dead when in fact it was the psu 12v rail which had died. because the board was still getting poweri assumed the psu was fine but when the rampage wouldnt start either i checked with a different psu and realised it was that.
anyway full specs are
d805 (yes i know its old but i am not changing until i get that 4.1ghz clock out of it)
rampage formula with 0410 bios
4gb dominator 8500+
7800GTX old but still works good
swiftech apogee
D5 pump
120.2 rad +res and other bits
Tagan psu
2 x 10k raptors
1 x 1tb spinpoint
so far i have the following
first attempt to boot it does nothing and the little post lcd says cpu init. after some fiddling with various parts i read that perhaps the previosu cmos settings were causing a problem so pressed the clear cmos button on the back.
it now boots up and aftervarious cpu fan arrors etc says press f1 for bios or f2 for load default settings and continue
i went into the bios the first few times and tried various settings as i had read that the ram may be trying to draw to many volts as the board only provides 1.8 and the dominator requires 2.1v so i tried that but i have never so far been able to get it to save settings and then post again. each time it will hang at various stages on the lcd post display.
the other option was to press f2 and load default values so a couple of times i tried that. i can in fact get through and load windows with no problem but i cannot restart the machine then. if i click shut down or restart then it shuts down and hangs when posting.
i have made a few assumptions given that i can get into windows sometimes that none of the components are bad and that it must be a problem with the settings on the board.
i could have course be totally wrong there but can you please help me as i just want to have a working pc again. currently stuck with my work laptopfor all internet activities
4gb dominator 8500+
swiftech apogee
D5 pump
Tagan psu
2 x 10k raptors
1 x 1tb spinpoint
