Hi,
I've recently been getting blank screen crashes which are blue screens in disguise (if I wait long enough after the crash the BSOD will come up).
The screen will suddenly go black during gameplay & the sound will start looping. Eventually the screen will go into standby. About a minute later the PC will beep once like it's posting, a bit after that a blue screen will come up, I guess this is Vista's way of trying to restart the driver and failing resulting in a BSOD.
This sometimes happens after hours and hours of game play and sometimes after only a few minutes.
I have monitored my graphic card temps using my G15's LCD & they don't go over 82 (playing Titan Quest - this game will make your graphic card hot hot
). 82 is fine for a 8800GTX as far as I know.
Specs:
Vista x64
4x 1GB Geil 4-4-4-12
Gigabyte P35-DS4
Conroe E6600
BFG 8800GTX
I'm on the latest 175.16 drivers.
So far I've tried reverting back to the 169 drivers using a combo of DriverCleaner and safe mode as well as normal reinstalls.
* I've just tried uninstall/reinstalling the drivers in safe mode using DriverCleaner and some manual deletion of files. (had to remove nvlddmkm.sys myself).
The Minidump reports nvlddmkm.sys causing the crash.
* I haven't been in game after this one yet.
[Edit]
Nothing is overclocked. System is extremely stable other than this. I can successfully run Orthos overnight with 0 errors.
While I test if it still crashes after my most recent 'fix' attempt has anyone had this problem before and been able to fix it?
Thanks,
Craig.
). 82 is fine for a 8800GTX as far as I know.Specs:
Vista x64
Gigabyte P35-DS4
Conroe E6600
BFG 8800GTX
[Edit]
Thanks,
Craig.
