Random lock ups - memory?
26 Feb 2004
Hampshire, England.
Hi guys,
My gaming rig had been playing up for a while now, very randomly though,so difficult to pinpoint. I'm thinking the ram, I'm currently using 4*8GB matched Corsair sticks at the moment so it's possible something is hidding there.
Tonight, and my rig is stock and very well cooled, I had a browser window running and Teamviewer session going - that was it. Then things started to hang... I couldn't even shutdown in the end, had to force it.
Is there anything I can try before checking in with Corsair, possibly even investing in 2*16GB sticks?
Thanks.
How long did it work okay?
Have you run any diagnostics on the hdds/ssds (and looked in event viewer for errors)?
XMP turned off?
XMP turned off?
My build has been rock solid since 2020 - and its had an absolute hammering! But in the last few months it has become a bit sketchy...
I had a couple of bsod a couple of weeks back but touch wood, that was a bad driver issue and appears to have sorted itself with updates.
My nvme C drive seems fine, a bit warm under load but nothing outrageous.
XMP is on but only so I can run the ram at their specified 3200MHz speed.
I think I'll start with some more memory testing ;)
There you are
There you are
I've loaded the anta777 (low), any thoughts on how long I should run the tests for?
