PC Specs:
i7 8700k
EVGA FTW3 1080ti
bitfenix Formula 650w PSU
16bg ram @2400 Mhz
b360 Motherboard
1tb HDD
240g SSD
3 120 mm fans
I seem to be losing power during gaming sessions, not always after a long time either. For example - Total Warhammer 2 certain campaign missions just cause the PC to reboot as soon as I select them, but other times If I avoid that mission I can play fine for 3/4 hours +. I've tried lowering the graphics settings (can sustain 144 fps @ 1440p on high just fine) to low across the board and doesn't seem to make much difference. Have also experienced it with Vermintide 2 but that seems to be more random and generally after a few hours in game.
Temps on everything are fine when I check them immediately after the reboots - graphics card 40-60 (at most), cpu similar, ram similar etc.
System just full reboots as If i'd clicked the restart button without warning. My immediate thought is PSU but it's 9 months old and realistically the wattage should be completely fine. I do have a 2k monitor but not sure if that would affect anything? Anybody got any ideas? Would love some advice or help diagnosing!
i7 8700k
EVGA FTW3 1080ti
16bg ram @2400 Mhz
b360 Motherboard
1tb HDD
240g SSD
3 120 mm fans
