Randomly System Make Device Sound and Detects usb2 as usb1
24 Feb 2008
Hi,
I built my system and have now properly started using it.
Randomly in Windows, the system makes a "Device Connect" and "Device Disconnect" Sound and says the usb device is plugged into a slow port and can be faster... whats going on. The scanner device also started reinstalling once redetected. I think this has happened on a Sandisk usb key now.
I can't say if i had the same issue with my previous mobo which was rma'ed. The mobo is the same so i didn't have to reinstall everything.
Driver or hardware issue? and what shall i do?
I'm going to try and reinstall the chipset software.
Which one am i supposed to install.
Vista 64bit
Version 8.3.0.1013 2007/09/20 update
Description Intel(R) Chipset Software Installation Utility V8.3.0.1013 for Windows 2000/XP & 64bit XP & 32/64bit Vista(WHQL).
File Size 3.23 (MBytes)
Vista 64bit
Version 8.3.0.1013 2007/08/02 update
Description Intel Chipset Inf Update Program v8.3.0.1013 for Windows 32bit 2000/2000 server/XP/MCE/2003/Vista & 64bit XP/2003/Vista(WHQL).
File Size 26.33 (MBytes)
check in the bios the usb ports are set as full speed and not hispeed
i think it's that naming scheme (it tells you in the bios which is usb2)
but then why Randomly in Windows, the system would make a "Device Connect" and "Device Disconnect" Sound???
i've reinstalled the chipset software. Can't remember which one i installed last time though.
also changed usb bios setting from hispeed to fullspeed.
Just Please don't happen again :-(
Even after updating the drivers, its happened again.
Faulty replacement motherboard as i never had this with my previous one. Its an exact replacement.
What shall i do now?
