Can you guys check this bench out, its the long bench with HD Tach, i cant remember what i set the stripe size to, bt i can remember i left it a default (Optimum), how can i find out?
littledave said:Can you guys check this bench out, its the long bench with HD Tach, i cant remember what i set the stripe size to, bt i can remember i left it a default (Optimum), how can i find out?
RAID0 will be noisier than single drives because both disks will be reading and writing simultaneously.::: CooliceT :: said:i downloaded that test program yestaday,
i put both of my raptors 74gig in a RAID 0.
they are fast, must faster then i had in sata on there own. but a lot more noisy. when there writing data, or searching.
but i ran the program. is this ok?
they seem alittle jumpy. or is that just normal...
never done this before. so im new to it.
