Raptor PCB
18 May 2004
South London
Just found my old 36GB Raptor lying around,
I managed to snap the SATA connector on the PCB whilst poking blindly around my case :( the metal pins are still there & if youre carefull it still works!!! :eek:
1) Can you get replacement PCB's for these disk?
2) would it be worth it???
1) Yes, the easiest way is to get hold of an identical disk and swap the boards
2) Not unless you need to get data off the disk with the duff board because normally you've had to get a working disk to get the board.
