Raptor? Yay or nay?
I got the 16mb cache version for o/s and 160MB WD 16mb cache for storage, one thing to remember is that the raptor is noisier than your average hard drive.
ah. storage is needed for me anyway so i was thinking maybe getting a 500gb for now and getting another 500gb later for raid.
I read this in a magazine the guy was asking weather he would be better off getting Raid, a faster HD (a raptor basically) or just go for maximum storage.
The answer was simple and quite effective.
Would you rather spend 5 seconds less loading your level of FEAR or your OS or would you rather have triple the storage space for the same price.
5 seconds is a long time if u think about it? Thats 1680 seconds per year!
I was thinking of getting the 36gb to do just that.,.. but then i read that 7200.10 are almost as fast as anyway... therefore it wouldn't make sense for me to pay silly amounts for just a small amount of space.
I'm not sure how loud the 36GB Raptor is, but the 74GB Raptor is ever so loud when seeking, I have a 150GB Raptor & that is abit better in terms of speed & slightly quieter.
I've just upgraded to 2 Seagate 500GB 7200.10's & I'm more than happy - quiet & fast. :)
The 36gb 8mb Raptor is :
Noisier
No faster
Smaller
Not got much going for it tbh, nor do any of them IMO, too expensive for what they are. If you MUST have a Raptor, dont consider any except the 150gb.
But you got remember that less loading time/copying time/installing/uninstalling time etc for everything.(I.E check mail,open webpage,start nero,install app/game etc)
I RMA my 150mb raptor last month,and i hated using a standard harddrive while waiting for the replacement raptor to come back,after being so used to using the raptor for a year..
The Harddrive is just about the slower component in a PC,So i would go for the fastest one you can afford...
Sold my 74Gb Raptors (RAID0) over a year ago, and have never been tempted to replace them.
Too noisey, and too pricey for the size.
I have a 150 GIG raptor as my windows drive.Its in a silentmaxx enclosure and its silent.
I have just got used to it now and will always use one as my boot drive.
I have now partitioned it into two 75 gig chunks.
One for XP and the other for Vista.
Sounds good mate... But i think I may go for 2x 500gb or 2x 320gb seagates and go raid 0 ;)
Raid 0 is good as a windows setup with say two 80gig seagates.
All you loose is the installation.
However for storing data raid 0 is pointless.
The only way a raid 0 setup is good for storage is when having say two 500 gig drives in raid 0 as a scratch disk when editing for temp video files.
