Hello
Not sure if this is the correct forum, sorry if not...
I've got a project in mind but haven't a clue where to start researching. I was basically wondering if the below is possible using a PI, Arduino or other "device"
1) receive a voltage input from a relay contact
2) energise an "output" relay when the above input is received
3) connect to an IP network with other PIs / Arduino / other "devices" doing the same job in another location but on the same network.
4) an input received on "device" 1 could also trigger an output on other "devices" on the network
So can this be do done? If so, what's the most efficient solution and how difficult would this be to learn myself? I'm tech savvy, electrically minded etc.
Thank you for your time.
Mike
Mike
