Rate my paving layout :)
I wouldn't seal it whilst wet, but given its going to get a fair bit of use and most likely have BBQ and drinks up there, what's the downside ?
Thanks - the supplier website does reccomend it's sealed
"Care & Maintenance
Sandstone is permeable which means it is not impervious to spills and weathering. Therefore to better protect your stone we recommend using a natural stone sealant (Pavestone Natural Finish Sealer) a water-based impregnator that ensures protection against stains and facilitates everyday maintenance."
Its lashing it down now so suspect they won't even bother coming today to joint it. I'll speak to them about sealing at some point in the future
Just been looking at what's left over and have enough for a small patio
Think once the extension is complete I'll be getting some more slabs and start replacing the existing paved areas
Thompsons patio ruiner? It is junk. Quality sealing products are not cheap.
What are the differences and advantages of the pricy stuff?
Never used it, but I always thought Thompson's was the go to product for this type of thing.
I've used the no nonsense one and it was fine. Not noticeable when dried and was water repellent. Not sure how long it lasted as I moved a year later! but it was fine up to then.
Noticed the £99 one is water based, while the others are solvent based. This Sika product is water based;
https://www.diy.com/departments/sika-natural-stone-sealer-5l/5055492702999_BQ.prd
My Indian sandstone patio has been down for 2 months now, it's gone through several wet/dry cycles with the changeable weather, and it seems that the more it weathers, the better it looks. It's not been sealed, the bare stone is exposed to the elements.
I'm just leaving it now.
I had my gray Indian Sandstone laid last September. The guys used StoneMarket FastPoint which looked okay when they did it but over winter, some of it has changed colour and has gone a sandy colour. I contacted the manufacturer to see if it was a faulty batch. They've come back saying it's organic growth and recommended their "Green Away" product, a cheap £60! Others have recommended bleach so last week I tried using a 4:1 mixture of bleach with water, will see what effect that has.
They are just surface sealers not proper impregnators which really penetrate into the stone and protect it. I think oil based would be better if you are going to use one as it will protect better than water, however the stone needs to be a bone dry not just the surface.
LTP mattstone is a reasonably priced impregnator. https://www.pureadhesion.co.uk/ltp-...eMOtsvZN0d-Q8YkfzHwg49Q36h45PcqhoCOfkQAvD_BwE
Thanks. I'll bear that in mind as I'm hopefully having a patio laid in the next few months... If I can find someone to do it. Everyone is booked out for the rest of the year !
