That is - the pads on the sides for cushioning your grip, not the ones underneath for sliding across your desk.
I have the Steelseries Rival 650 - which I found out after owning for a while is notorious for the sticky stuff which holds these pads in place failing. And it has happened to too large a degree to put up with on a couple of the pads.
So I have removed and cleaned them up. But what am I best sticking them back on again with?
I've ordered some Gorilla gel superglue. But if anyone has suggestions for what would be a better choice, I would be grateful to hear it.
For that matter - and suggestions for getting the surfaces really clean so the glue will work better would also be good. They're still a bit tacky in places after using nail polish remover.
