Phil W said:When you say re-furb, do you mean restore?
Is it currently black plastic at the moment?
What are you planning on changing it to?
Tesla said:I think you need to key the plastic and then use special plastic primer.
Phil W said:If you rub them down, you will have th get them uber-smooth, otherwise you will have bits textured and other bits smooth.
TBH i would clean them up with meths, then get plastic primer on without rubbing down (unless you want to put the work in) and it should be fine.
Mask off the chrome in the strips.
Matt black should be good enough![]()
I want them perfect, so i'm prepared to spend a lot of time on them, I don't mine driving around with no trim on for a while.
D4VE said:Get some vinyl dye spray paint from Halfords. It is absorbed partly by the plastic so wont peel off and "bends" to a cerain degree before it cracks etc.
eidolon said:That would be my suggestion too. Dye it rather than paint it.
eidolon said:It's not expensive, maybe £10-15 per can? (not sure how much you want to spray though).
My mate did various bits of his car with it, seemed to hold up pretty well. The only bit that wasn't too good was his steering wheel which he'd dyed as it came off after a few months.
