Re-using LED light strips.
Caporegime
3 Jan 2006
Chadderton, Oldham
I have a govee RGB light strip, I recent took it off my tv, and the sticky stuff has lost its stickyness and gots all sorts of bits on it.
Is there anyway I can re use them?
I’ve only used similar to what I’ve posted, but no reason why the cheaper stuff won’t work.
LED strips aren’t exactly heavy.
Might be worth trying to find some double sided tape that is the correct width. Otherwise really annoying trimming will have to take place. But otherwise I wouldn't be removing the old stuff (if you even can without destroying the strips).
I used some canopus stuff awhile back
Came with a little slide out razor blade :O
I was like is this even legal in the UK lol... I'm guessing your not allowed to send knives by post without an ID check?
ahh I found a pic of it on amazon
almost like a stealth knife
