Reading Nvidia GPU Temps How??
15 Oct 2007
Bedfordshire, UK.
How do i see what the tmeps are for my 8800GT??, ive gone into Nvidia Control Panel but cant see an option for view the temp??
Use Rivatuner, great bit of software, not only can you read your temps, but you can set up fan profiles to control the temperature of the card.
My Nvidia control panel has my temperature built in to it, if not use Ati tool as Ageidiot said and minimize it, should appear at the bottom in the tray
"...or use rivatuner which is ten times better."
As he said; Rivatuner is a brilliant piece of software. Have mine set to display not only the 8800GT temp in the taskbar, but also the temps of the cpu, and the cpu usage as a bar chart.
I have an after market heatsink and fan fitted to my 8800GT the fan is plugged into AUX4 on my mobo. Is it possible to set up this fan to speed up when temps on the GPU get to a certain level??
But i cannot see an option to tell rivatuner that my GPU Fan is connected to AUX4 Fan input on my mobo??
