FidgitUK said:Ok you know readyboost with vista, well are there any particular memory sticks that are recommended or will any stick do?
Also is there a size limit?
Thanks in advance.
NathanE said:Any stick will do just fine. Some manufacturers have already started cashing in by putting "optimised for Vista" etc on their packaging but it's just balony really. As far as Vista is concerned, it doesn't care about throughput as it only reads 8KB chunks at a time anyway. It does however care about seek time, but of course, all flash memory is largely the same here - a few micro seconds compared to 10 milliseconds or so for a typical hard drive.
No size limit.
Fantastic!Matt Ayers said:Since this is the first revision of the feature, we decided to focus on making the single device exceptional, without the difficulties of managing multiple caches. We like the idea, though, and it's under consideration for future versions.
No size limit.
durbs said:Although i notice the Corsair Readyboost drives and the equivalent sized Corsair 'normal' drives are the same price which was a pleasant surprise, i was fully expecting them to whack a few token quid on there for the Vista marked ones and they didnt (so i bought a 1 gigger as they're so cheap these days).
Gibbo said:Hi there
I got one of the 1GB TurboCache Readyboost pens today as well.
Dunno if its any benefit to my system but for the small amount of money I thought why not.![]()
