Deleted member 61728
Hi what is more accurate for measuring temps on a B3 q6600 ?
Thanks
Thanks
Fair deal, what cpu block do you recommend?,will it fit a Gigabyte p35_DQ6 mobo nice and snug ?There is usually a 10c difference between Real Temp and Core Temp. They use a different T-Junction setting, with Real Temps being roughly 10c less than Core Temps.
50c sounds a little high, but then it is a B3 running with a Apogee GT. The B3's tend to run hot, and the GT isn't really designed for quads. They're not really a great combination tbh.
