Hi all,
I rebuilt my water cooling rig back in June and within 2 weeks the water started to go cloudy. I posted on here shortly after that for advice but I haven't changed the water yet because it appeared to be only leaching from the tubing.
Anyway, since then it's continued to get worse and worse and now there seems to be a film on top of the water in my res with stringy white bits moving, like a reef sort of when the pump is on. I am using the feser bi-distilled water, silver kill coil and corrosion blocker. The only things that has changed since the last setup is my heat killer 7970 water block, pump and the tubing. The pump is the same model as last time. My previous rig was absolutely fine for 3 years and when I drained it the water was as clear as the day it went in so I think it must be to do with the tubing this time.
I really don't want to pull the rig apart and replace the tubing as I simply don't have the time to do it yet. I was thinking I might siphon the water out from the rest and put some more in to flush it a few times and then replace the water again. Do I get the same water or shall I go for something completely different? By the way, my temps haven't been affected at all.
Thanks,
RoEy
Thanks,
RoEy
