Really intense eye pain / head ache on plane landing.. (was almost crying)
Status
Not open for further replies.
Don
21 Oct 2002
Parts Unknown
I've had this twice (out of about 10 flights)
Was the worst pain I've ever felt in my head, felt like my eye was being stabbed from the inside of my head, and thought veins were going to burst etc..
Could this be just from having a slight cold?
:confused:
This happened to me once, it really freaked me out!
I went to the optician to get check out, and he told me that it was to do with having a cold/blocked nose.
yep, it'll be that. i had a cold on my way out to malaga a few months ago. it was excruciating. the pain in my eyes and ears was tear-inducing. felt like i'd burst my eardrum. that'll learn me to fly with a cold lol
I had the exact same thing! i thought it was just me. could still feel the pain 2 days after aswell! :( was behind my right eye and kinda running up behind my right eyebrow and right side of my forehead. extremly painfull!
good, was expecting something lame like oh, that's the brain tumor thingy, last thing i need right now
Suck a hard boiled sweet when you're flying, I hear that helps.
I would do that to stop my ears poping, but this pain is like nothing i've felt before.
It felt like i had grit in my eye for a few days after, was bloodshot etc.
While the plane was landing i honestly thought i was going to die or something, was close to telling the person sitting beside me!
when flying i constantly yawn, eat chewing gum etc to keep my ears re-pressurised, must be sinuses or something
had a slight cold for well over a year now, the doctor said "you'll get over it" when i said my nose had been running for over a year..
seriously though, horrible horrible pain
-edit: chucky, exactly the same mate, at the time i honestly felt like saying "tell the pilot to climb for a bit"
My wife got that when we were coming back from Cyprus, scared the hell out of her. Did some research when we came back and found it had something to do with not drinking enough water.
hmm..
first time i was disastrously hungover, and the second time I'd not drank anything that day..
those coupled with not having a large intestine doesn't help water intake :p , will bear that in mind next time i fly
The pain can vary depending on how much booze you have on the fight or so I found out when I went to America 13 hours and all the beer I could drink. Oh how my head hurt when we landed :(
i occasionally get it when flying. only on landing really. behind my left eye. last time it was painful for 2 days.
First couple of times I couldn't believe the pain.
I am fully aware of my high (ish) alcohol intake and lesser water intake, never thought it could be attributed to it though. I will bear it in mind.
I get this too sometimes. Once, it took hours after landing for my ears to stop hurting - especially when yawning often after a loooong restless flight. You may find the following article interesting to read:
___________________________
People with severe colds and sinus infections know that air travel can be painful. During a flight, the air pressure in the sinuses (collections of air within the facial bones) and middle ear must equilibrate with the cabin pressure inside the airplane, which changes during ascent and descent. Certain infections and other conditions can cause blockage in the Eustachian tube (which connects the middle ear to the back of the nose and maintains equal air pressure on both sides of the eardrum) or in the sinus openings, and this restriction to the flow of air can prevent the equalization, or equilibration, of pressure and result in pain. Examples of conditions blocking the equilibration of air pressure in the ears or sinuses include congestion caused by colds or allergies, middle ear infections, and sinus infections.
Pain is not the only symptom that may occur when the Eustachian tube is blocked. The pressure changes inside the middle ear may sometimes lead to vertigo (a sense of "spinning"), tinnitus ("ringing" in the ears) or hearing loss. In severe cases, rupture of the tympanic membrane (eardrum) may occur.
Most doctors would agree that avoiding flying when you have an active sinus or ear infection is the best way to prevent pain and possible complications, but if flying is a necessity, decongestants can be used in an attempt to overcome some of the blockages to air circulation. Both systemic (taken orally) and topical (nose drops or nasal sprays) can be used to treat congestion. Over-the-counter pain relievers can also be used to help control discomfort.
While you're flying, chewing gum or swallowing frequently, particularly during ascent and descent, may provide some relief. Giving a bottle or pacifier to susceptible infants can also help prevent pain. You should also learn the technique known as a Valsalva maneuver, which equalizes air pressure within the ears. To perform the Valsalva maneuver, simply hold your nose closed and attempt to exhale with a closed mouth. You'll hear, and feel, a faint "popping" (or sometimes a high-pitched noise, if you're congested) in the ears when you do this successfully.
A product developed for Air Force pilots can also provide relief to those with blocked Eustachian tubes. Called "Ear Planes," these ear plugs protect the eardrum from rapid or large ambient changes in pressure by allowing the pressure changes to take place slowly through a passage in the ear plugs. This slowing of the rate of pressure change minimizes the difference in pressure across the ear drum.
If you have had tympanostomy tubes inserted in the eardrums because of chronic ear infections or congestion, these should prevent the symptoms from occurring. Tympanostomy tubes are most commonly used in the management of chronic ear effusions (accumulations of fluid) in infants and children, but some adults require placement of tympanostomy tubes.
Interestingly, changes in cabin air pressure can also cause toothache in people who have diseases of the dental pulp. This rare condition develops when a small pocket of air localized inside a diseased tooth is subjected to changes in the surrounding barometric pressure.
Medical Author: Melissa Conrad Stöppler, MD
Medical Editor: Jay W. Marks, MD
gf has exactly the same problem as that, her optician told her to use eye drops just before landing, it worked from what i remember!
Status
