really low crysis bench test
my cpu couldnt have anything to do with it could it? I mean i used to run it at 2.88ghz and whilst i have been tested sli out i have had it back down to 2.4Ghz
The default test for crysis at 1280 1024 is somewhat cpu limited, Maybe try at a higher res?
Install your chipset drivers again.
Should be on the CD which came with your MB
Even with your CPU only at 2.4Ghz you should be seeing gains from the SLI.
Also keep the lowest clocked card in the top slot otherwise the least capable one is going to be overclocked too much.
With SLI both cards have there clocks set by the Video drivers.
That speed is determined by the bios settings of the top card.
which ones are my chipset drivers? Everytime i switch on the computer its going on about a pci bridge device and when i try to install the drivers for that its asking about nvnetbus.sys. Could that have something to do with it?
