- 1 Sep 2025
- England
Hey all
So I am a recently new PC gamer having built my PC a few months ago....and Ive had nothing but problems so far!
My parts are -
CPU - AMD 7600x
GPU - AMD 9070xt
Motherboard - Asus Rog Strix B650E-I
Ram - Crucial Pro DDR5 RAM 32GB Kit (2x16GB) 6000MHz CL36
SSD - Kingston NV3 NVMe PCIe 4.0 1TB
Case & PSU - Cooler Master NR200P MAX V2 Mini-ITX SFF Case - 280mm AIO Cooler, 850W SFX Gold ATX 3.0 PSU
PC is connected to my TV through HDMI.
The biggest issue I have had was where I could not even log into my machine as it kept freezing at the login screen - this was after just turning on HDR!
I think this was due to some driver issues as I installed Adrenaline and updated everything there but also downloaded drivers from the Asus website as I thought I needed those too.
I have done a full reset of the machine and reinstalled windows and now HDR is working - I only updated through windows update and adrenaline this time and I thought everything was going swimmingly.
I was playing Cyberpunk one day and workig perfectly - started it again the next day and its just tanking the FPS - I had it locked at 60fps but it was dropping to 50, 40, 30 and up and down, not running smooth at all but also the GPU power wattage was jumping up and down all over the place.
Deleted and reinstalled and working ok again - go to play last night and its doing the same thing all over again! Ive tried verifying the files which put in a 52mb update but still nothing.
These are just the 2 major issues Ive had not mentioning all the other small and annoying issues Ive had.
Is there anything else I can do or try to get things working better? Im at my wits end and have actually disconnected the machine now as its stressing me out so much! When it works its amazing but there just so many constant issues when I just want to have a game that Im wondering if its even worth it when I have my PS5 instead.
My parts are -
CPU - AMD 7600x
GPU - AMD 9070xt
