- 1 Sep 2009
- Doncaster
System spec as per my signature. Case fans were set up with one side exhaust and one top exhaust. The CPU liquid cooler provided a rear exhaust and the PSU also exhausted to the rear. In the current warmer weather I was seeing GPU temperatures peaking at 90oC but typically sitting around 80-83oC during a game of BF4. Case fans were both at full speed.
Decided to reconfigure the case fans today - just to see what difference it would make. I simply took the side exhaust fan and installed it at the front of the case as an inlet fan (keeping it at full speed) and reduced the top exhaust fan to the mid speed setting.
I then played a few rounds of BF4 to be sure I had generated some heat and was amazed to find the GPU temperature had levelled out at a maximum of 68oC; a reduction of 12-15oC compared to the previous typical temperatures.
Feeling very pleased with the result.
Andy
Andy
