- 2 Jul 2012
Hi guys,
I built my new PC last Saturday. I specifically chose the Fractal Design Define R3 case to make it as quiet as possible - I hate loud PCs. Unfortunately my 1TB Samsung F3 HDD has ruined my dream of having a quiet PC. It is by far the loudest component in my case; it makes a droning noise that is louder than even my optical drive when it is in use!
I'm going to send my Samsung F3 back as I suspect that I've just been unlucky. However, I would like to avoid this frustration in the future; can you recommend a HDD that is quiet?
). I do have hdd's though, 5400-5900rpm drives, and keep in mind that a lot of drives have settings for performance/noise. I have raid 0 Hitachi drives from ages back for my games drive for stuff that can't fit on there. THey are surprisingly quiet and I've also used an app that access's the setting so you can enable the acoustic something or other management. The biggest difference is the drives are less aggressive when seeking, you lose a little speed, not much, and the drives are massively quieter under heavy loads. When doing something like unraring they would chug/click/make a hell of a racket. Now they just make the fairly usual quite whine. Not perfect but it helps.
