Hi,
Bit of a story but the end result is the above message when booting from my RAID 0 SSD set up that has been working perfectly and was 30 mins ago!
Setup: -
2 * OCZ 60Gb SSD's in a 90Gb RAID 0 as boot drive
1 * Seagate 500Gb data drive
1 * WD Cavair 500Gb data drive
Asus P8P67 PRO Intel P67 Mobo
I added the WD drive today and went to set this up in RAID 0 with the Seagate drive through the Intel RAID controller using CTRL-I from boot.
Created the volume no worries. Reboot = no boot.
Thought that might have been because the BIOS had changed the boot order for some reason but that was still all set to SSD_RAID0.
Tried a cold boot and same again.
Went in to the CTRL-I utility and deleted the HDD RAID volume and reboot = Joy in to windows.
I set the volume up again and rebooted to the above message again.
Deleted the volume and still the same rather than a successful boot.
I have now disconnected the two HDD's but still getting the message.
It's like the boot record has disappeared!
Any help that would save me doing a reinstall would be greatly received.
Regards,
Simpic
Setup: -
Regards,
Simpic
