Reboot and select proper Boot device
22 Nov 2007
I get this message when windows would normally start up. I noticed that i couldn't see my HD listed in the BIOS and also i tried using the repair problem on the installation disc which also confirmed a missing hard drive.
The HD light is on constantly so does that mean its on? Im not sure if theres a seperate cable for the light and the HD itself. I'll have a look inside the case tomorrow to check connections, from what i can see everything looks ok though. Anyone had this before?
Is this a new build/rebuild? or has the system been running fine for a while n this just started?
If its new Id suggest you check everythings wired up properly, if its been ok n just started Id suggest you HDD has died, this may be the case on a new build also, it might be DOA
Assuming you mean the HDD LED on the case then yeah thats one of the little fiddly connectors on corner of mobo
