just humour me and play with the 5700x3d's voltages...stick these in:
Vsoc = 1.1V
Vddp = 1.0V
vddg = 1.0V
(they're safe voltages, no harm will come to the cpu)
set it to global and then type in the voltage for vddgso soc is at 1.13, vddp i can set but vddg as strage options i can just set a voltage
so VDDG is auto or global. the 2 options you ser under VDDG are what pops up after setting Global and no auto
I did. Set both to 1.0Did you look at the photo, it gives me 2 options both are vddg voltage
