Suspended
- 30 Jan 2005
can anyone reccomend me a good wireless router with built in modem, that can have wired computers hooked up to it aswell, thanks.
) than 4 switch ports now.Is there anyway of rolling back firmware with this kit - I'm using the latest version, but it does seem pretty wobblytolien said:The 585's mostly decent, but IIRC the later firmware's fairly rotten.
sam.wheale said:Is there anyway of rolling back firmware with this kit - I'm using the latest version, but it does seem pretty wobbly![]()
Starting to wish i hadn't upgraded now...
SW.
Sometimes the Internet light just drops out and I have to reboot to get a connection. The DSL light though remains constantCarter said:What problems are people seeing on the 585v6 latest firmware? I can't say I've had any, apart from maybe it's reluctance to drop the dsl signal, I've never had it drop once even with zero dB.
sam.wheale said:Sometimes the Internet light just drops out and I have to reboot to get a connection. The DSL light though remains constant![]()
Is there anyway back for me thenCarter said:Yep. In my opinion this router with the latest firmware is trying too hard to hang on to the dsl sync when it should just drop and resync, this is why a few people are seeing what you're seeing, PPP session dies but sync stays up.
sam.wheale said:Is there anyway back for me then![]()
Cheers,
SW.
Great - they all look like the original firmwaresCarter said:
sam.wheale said:Great - they all look like the original firmwares![]()
The v6 is there too http://m8s-rates.com/speedtouch/routers/585v6/
So just install them as you would an upgrade?
Cheers,
SW.
In the end I downloaded the 6.1.0.5 from the Dutch Speedtouch site, and it all went fineCarter said:sorry I mean't to link the v6 first.... Do a factory reset before and after loading the new firmware. I've never flashed to a previous firmware myself.
I've only had it on a day, but so far so goodsmids said:Funnily enough - the problem I have with my speedtouch is described above.
It keeps sync but no connectivity - i.e. the sync remains but the net goes down. It bugs me as it does this usually once per day. I'm on the 6.1.4.3 UK firmware. Which firmware doesn't have this issue? I'll look into 6.1.0.5 though as Sam seems to have had joy with that but there is a 6.1.9.x on that website....
