'Recent Applications' Stack on Mac OS X Leopard.
6 Apr 2007
Manchester
Hi,
Found this, i found it useful thought i wold post it on here to see if anyone else does, this piece of code places a stack on your dock called 'Recent Applications'
1) Open Terminal
2) Enter the following code: defaults write com.apple.dock persistent-others -array-add '{ "tile-data" = { "list-type" = 1; }; "tile-type" = "recents-tile"; }'
3) enter: killall Dock
4) You should now have 'Recent Apps' in your dock
Hope someone finds it useful :)
Certainly have.
There's 3 'recent' choices, 2 'favourite' and remove from dock options, in the right click pop up.
Ah right, I know why now.. didn't twig before because it was late :p
In the original Terminal command you typed, change the following;
Now, I haven't got access to OS X as this second, but it should be a case of experimenting with the number (in this case 1).
I'd try changing it to -1, 0, 2 or 3 and see what happens.
Regarding changing it to a list as supposed to a grid, i have been trying for a good forty minutes now cannot seem to get it to work, my only guess is that because the recent apps stack is not a folder it does not have the same behaviours with it being a system call. I will keep trying but im not sure i can be done....
Regarding what 'LordSplodge' said about it not showing up, just check your syntax for spaces and code errors, i am on the same os version as you so i cannot see why it wold not work. :)
Also if anyone has any problems with the dock after running this command, & a reboot doesn't fix it, remove the com.apple.dock.plist file from Users/YourName/Library/Preferences, restart. You'll loose any custom Dock settings or icons but it'll at least get your Dock back.
Hope this helps someone.
