- 4 Nov 2011
Can anybody recommend some decent rechargeable batteries and charger to use with quest controllers as i seem to be going through normal batteries at an alarming rate.
When picking the best Oculus Quest 2 replacement batteries, pay attention to any information they give on recharge cycles and usable battery life. You'll want at least 500 recharge cycles and several years of promised durability to ensure your battery won't suddenly stop working or lose its charge. That's one reason why we love the Panasonic Eneloop rechargeable batteries, which can recharge an absurd 2,100 times before you'll finally have to buy some new ones.
Battery capacity is also an important factor to consider, though perhaps not as vital as you might think. The higher mAh rating you see, the longer the battery will last and the more it can handle demanding electronics. But the Oculus Touch controllers aren't that demanding and are frequently in standby mode. Since standby mode doesn't use any real power, it's important to get batteries that can hold their juice for a long time, even when not in use. For reliable performance in both areas, the Panasonic Eneloop Pros have a solid 2,500 mAh while also retaining 85% of their charge for a whole year. Or, if you don't want to bother with rechargeable batteries, the Energizer Ultimate Lithium batteries have a massive 3,000 mAh capacity and can last up to 20 years in storage.
The Pro's are for high power applications and only have 500 recharge cycles, the white ones are better for the Quest and have 2100 recharge cycles.use these , last for ages
Panasonic Eneloop Pro AA 2500mAh
https://www.amazon.co.uk/Panasonic-Eneloop-Rechargeable-4BE-Batteries-Black/dp/B00JWC40JY/ref=sr_1_3?crid=YQ4M99Q9DHNT&dchild=1&keywords=panasonic+rechargeable+batteries+aa&qid=1627745521&sprefix=panasonic+rech,aps,151&sr=8-3&th=1
review of quest 2 batts
https://www.androidcentral.com/best-replacement-batteries-oculus-quest-controllers
I use these in my reverb G2 controllers they've been brilliant.
https://www.ebay.co.uk/itm/323939720139?hash=item4b6c4fdbcb:g:pwcAAOSwgqpdmh4G
Junk
Anything to back that up?
As well as what @amigafan2003 said, my favourite battery reviewer didn't think too much of them either:Anything to back that up?
https://lygte-info.dk/review/batteries2012/Kentli AA 2800mWh (Blue) UK.html
What is if Kentli really is the same as those, which seems to be the case.
Very different though.
I have got EBL and some Eneloops. The Eneloops are better (hold charge longer etc) but pricier. Ikea Ladda ones are also decent.
Different label, but same idea (all made in the same way).
https://budgetlightforum.com/node/69034
TLDR - less capacity than normal NIMH, have to use special charger, actual lithium cells are of unknown provenance (Ultra/Trustfire specials?).
Wouldn't touch them with a bargepole.
Found this old post..
What currently is a good buy for Reverb G2 controller batteries?
I have a load of Duracell 1.2v rechargeables. These only last about 1 session in my G2 but will go for weeks of use in the Quest 2 controllers. I’ve tried normal 1.5v non rechargeables in my G2 and tracking and haptic isn’t any different so not sure the lower voltage of the Duracells are an issue. Keep reading G2 needs full 1.5/1.6’ers
