That what i was thinking...No. The physical size of the battery doesn't affect the performance.
Chances are if you have a rechargeable D battery with a capacity that low it is just a AA in a padded jacket.
Exactly, most D size rechargeable batteries are actually AA batteries fitted inside a D size outer shell.
It's not density, if you pull open a cheap D cell it'll be have an normal AA cell inside, with air or padding filling the space.
That's just an urban myth taken from some stupid YouTube video. I'm not saying that some Chinese manufacturer hasn't tried it on but I doubt this is a common place event.
Nearly all D cells weigh a lot more than AA's
That doesn't mean they are that much better as the quality of the materials varies a lot, but neither are they filled with air.
The only certain truth is that whatever capacity it states on the label is always made up
Although true of non rechargable batteries, the rechargable ones, if the same mAh, will just be the same inside.
