- 18 Oct 2002
- Surrey
Right then, good people of OcUK linux I need me adistro to run as a test server at home. hardware will be a knackered old Dell P233 with a mere 64Mb of RAM.
Requirements are to host test web sites, so it needs to basically have what a hosting provider would provide, apache, MySQL, and any other stuff to allow me to configure it from a remote browser.
Not fussed if it has a GUI or not, command line is just fine, I need to be able to install and configure the OS and apache and then have the rest of the admin (setting up domains and sites etc) to be performed through some sort of web interface. The machine itself will move into a cupboard and run headless for the forseeable future.
As you can probably tell I don't really know what I need
If the distro in question doesn't come with one I'd like a decent install guide as well.
Thanks in advance
paul
edit it would appear that I need a <insert OS here>AMP install and freeBSD looks to be a good option for low spec systems, anyone care to offer comment?
Thanks in advance
paul
