- 31 Dec 2012
- Ripon
Hi - I have been building machines for about 30 years now , but my health is not what it should be & i need to upgrade my current loop so there is less maintenance required.
I can probably clean the loop as needed every 6 months. But i have to admit i am crap at modding.
My current PC setup is as follows.
Cooling Custom Loop Parts
As the hdd drive bays can now be removed and something put in its place . i.e. D5 - i have no/ little skills in modding but i have a drill!!
To briefly recap i need to replace mobo, cpu waterblock, new ssd & new tubing & might as well replace fans. With a possible radiator replacement.
I have not & wont buy a pump/cpu block kit. I have too much invested in custom loop parts & i will eventually be adding a waterblock to gpu in about 6 months.
I have a limited budget due to being out of work & disabled now.
So please some help with ideas on parts etc.
Thanks
Chris
- Case : NZXT Switch 810 with DECMiflex filters.
- Motherboard : M5A97 LE R2 - requires replacement
- CPU : AMD FX-8350
- Memory : Kingston KHX1866C10D3/8GX (32gb)
- GPU : XFX Radeon R9 290X DD Black Edition
- PSU : Corsair RM650
- Drives : SSD Samsung 840 Evo Pro 250Gb
- 2TB wdc 20EARS fitted in hot swap
- 00gb hard drive to be removed(drive failure) replacing with undecided ssd
- GRID+ for fans
- Koolance Radiator Mounting Bracket with Quick-Release
- XSPC D5 Photon 270 ReservoirPump Combo
- Cuplex Kryos PRO -needs replacement
- Tubing - needs replacement
- Radiator is similar to https://www.overclockers.co.uk/coolgate-g2-radiator-10-fpi-360mm-wc-002-cg.html - i am thinking of replacing due to age / unknown brand.
Thanks
Chris
