- 7 Sep 2012
- Lancashire, England
I'm buying a better case for my brothers PC as all of his temps seem a bit high (his current case is quite small and cramped inside with minimal airflow).... Now i'm also thinking about upgrading his GPU but i want to avoid bottlenecks and keep it relatively cheap! Will a 2GB GTX 660 or even a cheaper 2GB Radeon 7850 be a nice upgrade from his old 1GB Radeon 6850? I'm also assuming his Phenom II X4 955BE (3.2GHz) shouldn't be much of a bottleneck? I think anything higher than a Radeon 7870 will probably be wasted though... What do you guys think?
His current specs:
AMD Phenom II X4 955BE @ 3.2GHz (stock)
8GB Kingston DDR3 1333 RAM (2x4GB)
Gigabyte GA-870A-USB3L Motherboard
1GB Club3D Radeon 6850 (factory oc'd)
550W XFX Core Edition PSU
Windows 7 64-bit
Cheers
His current specs:
Windows 7 64-bit
Cheers
