Recommend A USB 3.0 External Hub
26 Jan 2009
Crewe
As above, anyone got some experience with some USB 3.0 external Hubs? which one's would you recommend.
I've been looking at the Belkin 4 port hub which isn't available in the UK for some reason, Also looked at star tech's 4 port hub which is what i'm considering buying, available for £30ish.
Thanks.
Edit: Sorry if this is in the wrong section.
Hi Zaim,
I don't have a lot of experience but I have been using the previous generation of this hub - http://www.trust.com/products/product.aspx?ProductCategory=CONNECT&ProductGroup=USB-HUBS&artnr=17908
which isn't 'curved'. It has been faultless running with my Asus P8Z77 WS based rig.
My case doesn't have USB 3 ports on its front so I Velcro the hub to the top of my case so it is handy to use.
Regds, JR
Thanks for your reply, that one looks alright. I'd prefer a belkin,startech etc tbh.
