Recommend me a decent quality USB 3.0 flash drive...
2 Jan 2004
Chesterfield
I appreciate the Samsung drive represents better value for money but I just want a smallish USB 3.0 drive that I can just hook onto my keyring!
The extension cable looks a good idea too as my USB 3.0 port is not very accessible - does anyone know if there is any drop in performance when you use one?
Thanks......
Thanks......
The dirves you were looking at are a bit bulky. I had an older USB 2.0 version and its was a bit if a pain once poped into a USB as it restricted use of others around it.
On a plus note, It was very quick (even for just USB2.0) and very reliable. Never had it fail on me. I just eventually lost it :mad: like pretty much every other USB Flash Drive ive had. lol
No drop in performance, certainly not over that distance anyway. I used one in my old case, In the case I have now I used what should a gap for 3.5" and popped something similar to this in
http://www.overclockers.co.uk/showproduct.php?prodid=CM-023-AK
used an extension cable to this and now you have some nice usb3.0 ports which are easily accessible :)
