Recommend me a good mini DV camera please
Caporegime
24 Dec 2005
Autonomy
I need a good mini DV Camera that has good features and good price.
Can somone give me 4 to look at ranging from £200 - £500 please
I will want to connect to PC via firewire does it need DV in aswell as out?
Thanks.
Easyrider
You only need DV in if you want to put a video edited on your computer back on to MiniDV tape. It's a good way to back up edited video.
Have a look at the Panasonic NV-GS500. It's 3 CCD and has full resolution wide screen. It can be got in the UK for around £500 if you shop around on the Internet.
Just ordered a Sony DCR-HC24 MiniDV Camcorder. Awesome spec. Good reputation. Can be bought for around £200 if you shop around.
The Sony's have excellent specifications, but the battery life is not very good, and the touch screen is annoying when you want to change a simple setting, and have to navigate through menus rather than use dials.
what about the Canon Elura 100 ?
it seems this come ahead than than the Sony DCR-HC46 HC Style Mega DV with DV-IN in reviews.
I've got the GS180 (the cheapest 3 chip) and it's quite a decent piece for kit for £300.
Panasonic seem to be good for the sub £500 price range, but if you go higher then sony would be a make to go for.
